Hello Guys,
and thank in advance for your help.
I am trying to connect a Raspberry Pi 3 to Thingworx using the EMS 5.4.
I am able to autobind in the config.json file but if im trying to bind it via LSR its not connecting.
Also the Properties dont get connected.
config.json
"ws_servers": [{
"host": "172.20.1.18",
"port": 80
"appKey": "xxxxx",
"http_server" : {
"host": "localhost",
"port": 8085,
"ssl": false,
"authenticate": false
"logger": {
"level": "INFO"
"auto_bind": [{
"name": "Am2302Thing",
"gateway": false
"certificates":{
"validate": false,
"allow_self_signed": true
"ws_connection":{
"encryption": "none",
"verbose": true,
"msg_timeout": 1000
config.lua
scripts.log_level = "DEBUG"
scripts.Am2302Thing = {
file = "thing.lua",
template = "Am2302Template",
identifier = "2302",
scanRate = 10000,
TaskRate = 300000
scripts.rap_host = "localhost"
scripts.rap_port = 8085
scripts.rap_ssl = false
scripts.rap_server_authenticate = false
scripts.script_resource_host = "localhost"
scripts.script_resource_port = 8086
scripts.script_resource_ssl = false
scripts.script_resource_authenticate = false
Greetings Niels
Hello.
This is a known issue with EMS 5.4 and a bug has been reported.
The suggested workarounds for the time being are to either enable SSL in EMS 5.4 using TLS encryption or to downgrade to EMS 5.3.4.
-- Craig A.
Hello.
-- Craig A.
Hello Craig,
its now working because i am using the EMS 5.3.4.
but out of curiosity how should i configure my files to enable SSL, because i think i tried it too but it didn´t work.
Thanks for your Help
Greetings Niels
