Hello Guys,
and thank in advance for your help.
I am trying to connect a Raspberry Pi 3 to Thingworx using the EMS 5.4.
I am able to autobind in the config.json file but if im trying to bind it via LSR its not connecting.
Also the Properties dont get connected.
config.json
{ "ws_servers": [{ "host": "172.20.1.18", "port": 80 }], "appKey": "xxxxx", "http_server" : { "host": "localhost", "port": 8085, "ssl": false, "authenticate": false }, "logger": { "level": "INFO" }, "auto_bind": [{ "name": "Am2302Thing", "gateway": false }], "certificates":{ "validate": false, "allow_self_signed": true }, "ws_connection":{ "encryption": "none", "verbose": true, "msg_timeout": 1000 } }
config.lua
scripts.log_level = "DEBUG" scripts.Am2302Thing = { file = "thing.lua", template = "Am2302Template", identifier = "2302", scanRate = 10000, TaskRate = 300000 } scripts.rap_host = "localhost" scripts.rap_port = 8085 scripts.rap_ssl = false scripts.rap_server_authenticate = false scripts.script_resource_host = "localhost" scripts.script_resource_port = 8086 scripts.script_resource_ssl = false scripts.script_resource_authenticate = false
Greetings Niels
Hello.
This is a known issue with EMS 5.4 and a bug has been reported.
The suggested workarounds for the time being are to either enable SSL in EMS 5.4 using TLS encryption or to downgrade to EMS 5.3.4.
-- Craig A.
Hello.
-- Craig A.
Hello Craig,
its now working because i am using the EMS 5.3.4.
but out of curiosity how should i configure my files to enable SSL, because i think i tried it too but it didn´t work.
Thanks for your Help
Greetings Niels
