Hi, how to achieve Carousel Effect in thingworx for showing multiple images.
While there is no out of the box ready solution for this, you could look into multiple alternatives. One would be to develop your own custom widget that would serve this specific purpose. I'm attaching documentation on custom extensibility. Another option would be to use the Html text area widget and embed your images in there using html code. Third option would be to use the Web Frame widget and host your carousel image on an independent website that you could then embed in the web frame.
