Certificate validation with purchased commercial SSL cert
gmcnamara
7-Bedrock
I have installed a commercial (purchased) SSL certificate for my domain on my Thingworx server. I can connect to Composer via https:// with no warnings from Chrome (it shows a successfully encrypted connection and valid cert), but when I try to connect an EMS to the server on port 443 with encryption set to SSL it fails with an error "TwTlsClient_Connect: Error initializing TLS connection. Invalid certificate". If I change certificate validation to false in the EMS config it connects ok, but surely that is an insecure setting that should not be used on a production server, right? Any ideas on how I can troubleshoot this?
Greg
Aanjan
(To:gmcnamara)
Greg, when you connect through the ems, how have you set the certificates flag in your config.json? If you have validate set to true, you would need to provide the cert_chain as well. Please do take a look at the config.json.complete.
Hi Aanjan Ravi,
I am also facing "Error in initializing SSL connection"  while trying to connect to thingworx server hosted with valid certificate . Please let me know how this can be resolved in the dot net SDK.
If possible, please provide small snippets for the same. Thanks.
Hi Team/Aanjar Ravi,
Anybody has done connecting dot net SDK to  CP using valid certificate. If anybody has done Please let me know  what configurations need to be done.
Thans.
