Chatbot Integration
Granite
Chatbot Integration
can u pls help me that how to integrate chatbot in thingworx?
7 REPLIES 7
Re: Chatbot Integration
I think you should start a separate thread about this?
What handles does the chatbot have?
Most of these are 'message' based I think? If that is the case, you will likely have to create a custom extension similar to some of the ones you find in the Marketplace like the MQTT extension.
Yes, message based only... please help me to do that.
Can u tell me the name of that extension?
https://marketplace.ptc.com/apps/193516/mq-telemetry-transport-mqtt
if you need something more enterprise, you would use the protocol adapter toolkit
https://marketplace.ptc.com/apps/217100/protocol-adapter-toolkit
Hii,
I am creating on e mashup, i passed the link into the webframe.  That link is working properly in chrome but it is not properly working in mashup ?
could u help for me  the above problem?
You might be running into CSRF or click-jack type issues. Or the website you are linking is not allowing embedding.
Hi @DMu3.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
