The official supported Chromium is 85+ on ThingWorx 9.1.0.
However , my customer will has 100 clients to use ThingWorx in the future , and the pre-installed chrome in the client's PC is 78 (in Win7 SP1 or Win10 1909) . It's forbidden to install new software and upgrade online in the customer's PC due to their IT policy.
So , is there any problem if use chromium 78 within win7 pro SP1 or win10 1909 on ThingWorx 9.1.0 ?
Sean
Hi @seanccc.
If you choose to run a version outside of the System Requirements, we can't predict whether problems will be encountered or not, because we have not tested on those earlier releases. If you run into issues, we may not be able to provide support if we determine the issue is browser related.
--Sharon
Hi @seanccc.
--Sharon
Hi @seanccc.
If you are satisfied that your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
