I am able close a popped up mashup on click of a button which is inside the popped up but I Couldn't close the pop up upon clicking a button which is not in popup mashup.
None of that allows to do what @krishnakomal123 asked originally:
This is currently not possible with ThingWorx, you can't close one mashup from another one.
/ Constantine
There's a checkbox in Navigation widget that's ClickOutsideToClose, thus you don't even need a Button outside the Popup, just click anywhere but inside.
That's right, you can't.
Hi KrishnaKomal123,
There are many ways to close the pop up. One is on click of a button you call the CloseIfPopUp. The other is to click on "CloseButton" option which gives you a X mark on the top right corner of the screen.
In your case you need to enable the "ClickOutsideToClose" checkbox. Even on any event of a service or function we can close the popup screens.
Hope this helps.
/ Constantine
