Collapse container to specific width in ThingWorx 9.3.0
VS_10550403
Hi ,
I am looking to Collapse a container in twx upto specific width , Is it possible in TWX 9.3.0?
Hi @slangley
I had opened a case and issue got resolved by applying CSS .
7 REPLIES 7
DanZ
(To:VS_10550403)
It is possible with custom CSS. But I can only get it do work for all collapsible container in one mashup and not for a specific one with a custom class.
.widget-flexcontainer-bounding-box.collapsible {
    min-width: 100px !important;
Hi DanZ,
you must be appreciated for the solution, but Unfortunately its not working for me at all.
Do we need any changes in properties of the container ?  FYI- this is TWX 9.3.0. you have the same one?
Vaibhav
DanZ
(To:VS_10550403)
I am using Thingworx 9.3.4 and also tested it in 9.3.6, so I think 9.3.0 should work as well.
For my test I just created an mashup with two containers. One of them is collapsible and has the icon for expand/collapse visible. Both of them are of course responsive.
I have attached the mashup as example.
Hi @DanZ ,
My bad , It's not working for me for responsive mashup only.  Can we connect for a while in MS Teams if you don't mind ?
Shall i share my ID If you invite me?
Vaibhav S.
DanZ
(To:VS_10550403)
Hi Vaibhav,
answering in this forum is just a "time filler" for me. Therefore, I do not provide support outside of this forum.
slangley
23-Emerald II
(To:VS_10550403)
Hi @VS_10550403.
If you would like to open a case, please let me know and I will be happy to open one on your behalf.  We can then engage with you in a call to walk through the issue and solution.
Regards.
--Sharon
Hi @slangley
