Collection Widget has an Binding of GetDataTableEntries(All Data)--> (Data)Collection.
But in the Collection only first Added Table Entry is getting duplicated to all other entries. DataTable or Base has 8 Entries, but the Collection widget is only showing the data of first entry of Database in all the remaining 7 Cells.
I did a quick test and I was able to display all the data table entries in the collection widget using GetDataTableEntries. I have attached the entities I used for your reference. You can compare my collection mashup with yours and if the still exists then please share the entities you created.
Thanks for quick reply, Your entities are exactly same has mine, I have only binded the GetDataTableEntries to the Collection Widget, the Same first entry is repeating the whole Collection Widget Cells.
Can you share the entities you have used? I will import them on my local instance and investigate. Please provide the Thingworx version as well.
