Collection widget positioning on the top (Thingworx : 9.3)
SB_10827459
7-Bedrock
Hello all,
As shown in below Image-1, for the boxes i used collection widget. in the normal desktop view, it is properly aligned with the arrows.
But if i make it full screen or display it in bigger screens, it is becoming like shown in Image-2., the unwanted extra gap between arrow and collection widget is coming.
can someone tell me how can i correct this issue, by using CSS can we correct this ?
Note : Here all are responsive containers.
@SB_10827459 ,
What my guests would be that the responsive container has a layout or positioning setting which indicates that a buffer space should be added between the lines and the collection elements. You might be able to remove the padding around the collection by using the approate theme or Custom CSS,
HTH
Pehowe
slangley
(To:SB_10827459)
Hi @SB_10827459.
There are some unknowns that make it difficult to answer your question.  Is it possible to provide your mashup?  If not, I suggest opening a case so an engineer can work with you on your layout.
--Sharon
