Color Picker widget is not working properly
Sankarapandian
6-Contributor
I used color picker widget to select the color and color code. But I faced some issues in Color picker widget. I mentioned the issues below and I have attached the screenshots.
1. Color selecting panel display is not visible in mashup. (Only color code selection is available).
2. When I using the color picker widget in navigation popup On the click The color and color code selection display panel is not came.
Kindly let me know if there any solution is available for this issue. and Kindly share the Properly working Color picker extension if you have.
Thanks in Advance,
Sankarapandian.L.S
For the moment, Color Picker widget is not available on PTC Marketplace. Probably the issues you reported are some defects, but for the moment it is not supported.
Best regards,
Raluca Edu
Thanks for the Response.
Is there any solutions to fix this defects?
