I am using two infotables containing latitude field in one and longitude field in another table.I have two questions.
1. How to join two tables having different different datashape as output.
2.How to concat the two coloums of infotable.Is there a function to do that.
Hi Isha, there's Union function for Infotable, which you can use to join two Infotables, however AFAIK this is working only for Infotables with similar DataShapes
Not aware if there is any other function available OOTB for joining to disparate DataShapes based Infotables
To concat two columns of infotables you should look at Derive snippet.
