Configure and Connecting Edge Micro Server With Thingworx
thambiduraisub
Hi Team,
I need help on configure andconnecting EdgeMicroServerSystem  with Thingworx.  Could you pleasehelp/guide me how to do that ?
So far i have done followingthings but I am not able to establish a connection.
1.We have copied the “MicroServer_Java”folder “C” drive.
2.    Changed the“TraningCofig” as bellow,
{    "ServerLocation": "localhost",
    "Port": 8080,
    "AppKey": "1c6d618d-61a7-4b29-a565-9c8ac01d6208",
    "Security": false,
    "RemoteRepo": "/ThingworxRemoteRepository"
3.      We run the batchfile called “wsjavavmstart” from “Microserver_Java” directory.
But I am getting themessage in terminal as below,
Endpoint not connected [name: EP_0,
id: 0]. Attempting /reconnect.
4.We have verifiedthat “WSCommunicationsSubsytem” is successfully running.
5.Created Thing Called“RemoteVendingMachine” and it is derived from “RemoteThing” Template.
<!/if !supportLists>
But if you look at “isConnected”properties of “RemoteVendingMachine”  is false. As per the trainingdocument this value should be true.  So I am not sure what I have donewrong, if you could help me on how to resolve this issue that would be great.
Thambi
Hi Thambidurai , could you reattach the screenshot, somehow it's not visible in your question. Additionally, have you checked the logs, are there any connectivity related errors?
KSM
(To:thambiduraisub)
Make sure that, while copying the thingname may be some white space included. check once that
