Hi everyone,
I built the following chart to demonstrate the hourly production of each production line that our customer has.
For this I created a data shape to compute the time and production of the lines.
After it I created a thing
Where in the properties and alerts tab I created an infotable associated with the data shape to store the necessary values, however these values were manually entered by me and I would like to link variables that I have in another thing, because when the value of the variable changes it will change the drawing of the graph. Is it possible to do that?
You could create a Subscription that listens to DataChange event of the property in the second thing and in the subscription code you could update the infotable with the new property values.
