Connect to On Premise Thingworx 8.5 using ThingWorx Academic Simulator
Praveen_GR
6-Contributor
Hi Team,
I am unable to connect to on premise Thingworx8.5 (Thingworx foundation Trial for H2)using academic simulator.
please find the screenshot.
Need guidance to resolve the issue
Praveen
13 REPLIES 13
slangley
23-Emerald II
(To:Praveen_GR)
Hi @Praveen_GR.
Is the Academic Simulator on the same machine as ThingWorx?  If not, you can't use localhost.  You'll need to use the hostname of the ThingWorx server.
Also, did you validate that you can hit the ThingWorx url from the machine running the simulator?
--Sharon
Praveen_GR
6-Contributor
(To:slangley)
Simulator and Thingworx are in the same machine.
yes I validated by accessing the thingworx url http://localhost:8079/Thingworx/Composer/index.html and it is working fine.
can we connect to on premise thingworx using academic simulator?
is steps need to connect to on premise thingworx is different from hosted thingworx?
Praveen
slangley
23-Emerald II
(To:Praveen_GR)
Hi @Praveen_GR.
Your port is wrong in the config for the Academic Simulator.  You have indicated port 8080 there, but in the url you provided for ThingWorx, it's 8079.
--Sharon
Praveen_GR
6-Contributor
(To:slangley)
Tried with port 8079 also but still not able to connect.
Please find the below screenshot.
slangley
23-Emerald II
(To:Praveen_GR)
Hi @Praveen_GR.
Is it possible there is a space before the port number?  When you created the appKey, which user was set up in the "User Name Reference" field--possibly a permissions issue?
After checking the above, if it's still failing, please provide the Application Log located at ....ThingworxStorage\logs\ApplicationLog.log.
--Sharon
Praveen_GR
6-Contributor
(To:slangley)
Initially used the administrator in the user preference on creation of application key.
Then created a user "praveen" and created a application key with user "praveen".
Still the same issue exists.
Please find the attached  application logs.
Praveen
slangley
23-Emerald II
(To:slangley)
Hi @Praveen_GR.
I'm afraid I'm out of ideas.  We can either open a case in order to take a look at your system, or you can reach out to the Academic team for further support.  To contact the Academic team, send an email to support@ptcu.com.
If you prefer to open a case, please let me know, and I will be happy to open one on your behalf.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @Praveen_GR.
It looks like a permissions issue.  Try changing the "User Name Reference" back to Administrator to see if it works.
--Sharon
Praveen_GR
6-Contributor
(To:slangley)
hi,
created the application key with administrator.
used the port number same as the application url localhost:8079.
below is the message displayed.
when i used the port no below message is displayed.
Praveen
slangley
23-Emerald II
(To:Praveen_GR)
Hi @Praveen_GR.
If ThingWorx is running on port 8079, there's no way port 8080 would ever work.  Please trying clearing the port field and re-entering port 8079.  It still appears there may be a space before the port number.
--Sharon
Praveen_GR
6-Contributor
(To:slangley)
There is no space and also cleared the port number and entered the port number 8079.
I used the hosted(cloud) thingworx ,and was able to connect to hosted thingworx successfully.(used this one year before).
As my cloud trial version expired, used the on premise thingworx .is the steps that we follow for on premise thingworx is different from hosted thingworx(using academic simulator)?
Praveen
slangley
23-Emerald II
(To:Praveen_GR)
Hi @Praveen_GR.
You should be able to connect to your local instance in the same manner.  I tested on mine and had no issue.
What version of Windows are you running?  Any security policy in place that could be affecting your connectivity?  You could try changing localhost to the name of your system, though localhost worked on mine.
--Sharon
Praveen_GR
6-Contributor
(To:slangley)
Using windows 10 Home edition.
Praveen
