Hi Team,
I have installed thingworx with postgreSQL Database. In order to fetch data from other sources, I am trying to connect twx to an external MsSQL database running on another server. Could you please help me out with this?
You can refer below article and developer portal tutorial for detailed steps,
https://www.ptc.com/en/support/article/CS318728
https://developer.thingworx.com/resources/guides/external-databases
Sachin Sharma
Hi @SachinSharma , Is is possible to fetch real time data with this approach? Also if you could tell the minimum data rate(eg per min/ per hour etc) with which it could be fetched?
@AT_10203640 Fetching real time data you mean data from devices or from the database? Can you please explain your use case?
Hi @SachinSharma, Sorry for getting back so late. Actually I am deploying a ML Model using an external PMML file. Now I have to get the input data for the Model from a table on MsSQL database. Also If you could help me out on how to give that data to ML Model, that would be great!
PS: It's a pre-trained model. I only have to feed data on which I need predictions.
Thankyou!
