Connection to Data source ODBC
kbadr
2-Explorer
I would like to ask for help; how can I connect to data source ODBC (eg MS access driver) with thingworx?
Or if there is other method to get data from excel (or csv file) to thingworx as infotable but not uploading file?
Thanks in advance
KB
supandey
(To:kbadr)
Karim you can consider using ADO Service from ThingWorx, allows you to connect Excel, Access DB or MS SQL Server to ThingWorx, how to set it up is covered in the blog Configuring the ADO Service for SQL Server DB connection For ThingWorx
