Connexion to The Things Network : MQTT support for + wildcard in Thingworx ? any progress ?
pjoly
Hello
I would like to connect to "The Things Network" using MQTT
The topics to subscribe  are like "+/devices/+/up" to get the uplink messages
It seems that these "+" are not supported by the MQTT extension
https://www.ptc.com/en/support/article?n=CS271034
Any progress on this issue ? new release of extension planned ?
pjoly
(To:mneumann)
thanks for answer and advice.
A little bit too complex for me, I was thinking a simple script in python between TTN & Thingworx to translate the topics.
Anyway , I found another workaround by using The Things Network http integration instead of default MQTT.
The new challenge was to convert base 64 to hexa without atob() function accessible in Thingworx to decode the payload. Fortunately I found a complete source to do that.
Regards
it works fine!
3 REPLIES 3
mneumann
(To:pjoly)
Hi @pjoly
It seems like this enhancement has not been intended for implementation in one of the next releases.
However, maybe the Protocol Adapter Toolkit could help you here...
There's an example of how to use it with MQTT at https://community.ptc.com/t5/IoT-Tech-Tips/Protocol-Adapter-Toolkit-MQTT-Sample-Project-hands-on-1-1-x/m-p/534701
Cheers,
Michael
pjoly
(To:mneumann)
it works fine!
pjoly
(To:mneumann)
Regards
it works fine!
