I've problem as the subject title
So, I following training from "ptc University"
in course "Implementing ThingWorx Dashboard" -> "Dashboards" -> "Creating Dashboard"
I followed guide in "Task 1" to "Task 3"
in "Task 4", after add "Contained Mashup" ( line 9 ).
in mashup properties I can not find the created gadget as mention in the guide. ( line 13-14 )
Please help
Hi @odukiya ,
Thanks for the reply
The tasks is about to create a Dashboard.
I'm stuck when try to create Mashup Gadget Library
I've attached the screenshot for the tasks.
Please take a look.
for the Environment, I'm using PTC Cloud for trial.
When you click on your containedMashup in the properties section you will find a Name field with search box and you will be able to find your already created mashups there. You can also refer the following article to create dashboard with Gadgets.
Please let me know if you feel any further issue.
Om Dukiya
Hi @odukiya ,
I've already following the guide
the "Gadget" that created not showing the the field "Name"
below is the Gadget
I try to search the Gadget and not found
I don't understand why
but I am able to add the gadget through "Mashup" tab, not using the "containedMashup".
Maybe it's bug ? or different Thingworx version
Thanks your help @odukiya
@odukiya I can also confirm that gadgets don't show up in the available list of mashups for Contained Mashup when I try to edit Name property, looks like a bug. I'm on 8.5.4-b222.
@martinwijaya, just use drag-and-drop from the Mashups tab, as you suggested -- it seems to work fine.
/ Constantine
