Contained Mashup can not find created gadget
martinwijaya
I've problem as the subject title
So, I following training from "ptc University"
in course "Implementing ThingWorx Dashboard" -> "Dashboards" -> "Creating Dashboard"
I followed guide in "Task 1" to "Task 3"
in "Task 4", after add "Contained Mashup" ( line 9 ).
in mashup properties I can not find the created gadget as mention in the guide. ( line 13-14 )
Please help
6 REPLIES 6
Hello @martinwijaya
Can you please provide more details about the tasks you followed?
martinwijaya
(To:odukiya)
Hi @odukiya ,
Thanks for the reply
The tasks is about to create a Dashboard.
I'm stuck when try to create Mashup Gadget Library
I've attached the screenshot for the tasks.
Please take a look.
for the Environment, I'm using PTC Cloud for trial.
@martinwijaya
When you click on your containedMashup in the properties section you will find a Name field with search box and you will be able to find your already created mashups there. You can also refer the following article to create dashboard with Gadgets.
https://www.ptc.com/en/support/article/CS209970?&language=en&posno=1&q=gadget%20library%20mashup&source=search&source=copyurl
Please let me know if you feel any further issue.
Om Dukiya
martinwijaya
(To:odukiya)
Hi @odukiya ,
I've already following the guide
the "Gadget" that created not showing the the field "Name"
below is the Gadget
I try to search the Gadget and not found
martinwijaya
(To:martinwijaya)
I don't understand why
but I am able to add the gadget through "Mashup" tab, not using the "containedMashup".
Maybe it's bug ? or different Thingworx version
Thanks your help @odukiya
@odukiya I can also confirm that gadgets don't show up in the available list of mashups for Contained Mashup when I try to edit Name property, looks like a bug. I'm on 8.5.4-b222.
@martinwijaya, just use drag-and-drop from the Mashups tab, as you suggested -- it seems to work fine.
/ Constantine
