Container border
Re: Container border
Hi @slangley ,
In the above picture there are 1st container has a label written manually, 2nd container has value of integer type (quantity), 3rd container has value of sting type (hh:mm:ss)
2, 3 containers are binded to property.
I'd like to do one the followings.
1- changing the colour of the value containers when their values are changing and the values start from 0 and 00:00:00, once incremented will not come back to initial values.
2- Bind another property which has 0 or 1 to value containers (I think not possible to bind two properties to one value widget) or label container and changing the colour.
Instead using the following to solve the issue, but one of above solution will be highly appreciated.
Thank You!
Hi @mnaeem.
Please check out this tutorial on CSS for addressing your needs.
Regards.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
