I extracted Java SDK and installed Gradle and put its bin folder in PATH on Windows 10.
I they imported Gradle (STS) project and selected samples folder and did the build model and after that I could import the project.
I then right clicked on samples project and I then run Gradle task quick launcher and choose "Steam" task. When pressing enter I got this error:
Process 'command 'C:\Program Files\Java\jdk1.8.0_151\bin\java.exe'' finished with non-zero exit value 1
Could not execute build using Gradle distribution 'https://services.gradle.org/distributions/gradle-2.2.1-bin.zip'.
What is supposed to happen after I ran the task? I couldn't find any tutorials, articles on how to use Java SDK project (3 independent samples are bundled in SDK project).
My goal is to start debugging it.
Thank,
Rad
Hello, Rad.
You are following steps similar to what is described in the below article, is the right? And the Java SDK Guide referenced therein?
https://www.ptc.com/en/support/article?n=CS226748
Let us know if that gets you started off in the right direction.
-- Craig A.
