Could not launch PTC Thingworx cloud hosted trial.
Getting message as Server cant be reached
Greetings,
This is the TWX DevPortal who manages your hosted trial. Some relevant information...
In addition, please note that if the 3-hour auto-shutdown is unacceptable for your investigation of our products, you can download and install your own trials here: https://developer.thingworx.com/en/resources/trials Simply click on the "LOCAL INSTALL" tab near the top.
Thank you,
TWX DevPortal
Wait for sometime for the instance to shut down due to inactivity and then restart it and see if it connects.
If you still have issues, please let us know and we will engage the team that manages those trial instances.
--Sharon
still i m facing the same issue .could not launch server
Greetings,
Thank you,
TWX DevPortal
If the previous response provided a solution, please mark it as the Accepted Solution for the benefit of others with the same problem.
--Sharon
