Creat things using a csv file_datashape
anassNasser
8-Gravel
hi community,
I want to creat 80 things from a thingTemplate, I Think I Can do it easily with a csv file but I don't know the shape of this csv file;
if anyone already used it, please share the shape or some good tips.
can we create alerte from a csv file too ?
thanks in advance.
4 REPLIES 4
PaiChung
22-Sapphire I
(To:anassNasser)
If you have the ThingTemplate already then all you need is the EntityServices/CreateThing service
yes you can create a CSV file with a list of names etc. you can name the columns anything and create a datashape to match.
Then use your service to provide the appropriate parameters from the parsed infotable (use csv parser or parsely) to loop through create entity.
hi ,
thank you for response, No I don't have the thingtemplate created, I want to creat all entities (thingTemplate, things,..)  from a csv file but I don't know what I should put in the datashape.
if anyone already did this, please share.
Thank you in advance.
slangley
23-Emerald II
(To:anassNasser)
Hi @anassNasser.
Have you found a solution to your question?  If so, please feel free to post it here and mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
hi ,
Thank you for rememberingme, but  I don't test it.
