Hi All,
I have created an infotable in eclipse extension and try to plot as a chart. I can able to see the data on grid by checking "ShowAllColoumns". But i can,t able to plot as chart.
How can i create a datashape with in eclipse and import into thingworx?
Thanks & Regards,
Sathishkumar C.
I saw in a widget here, and maybe you can try create a folder inside your zip file with the entities. Following the architecture:
- MyExtension.zip
That is the example of the xml file that defines the data shape that I found:
<?xml version="1.0" encoding="UTF-8"?> <Entities build="b140" majorVersion="8" minorVersion="2" modelPersistenceProviderPackage="PostgresPersistenceProviderPackage" revision="1" schemaVersion="1020" universal=""> <DataShapes> <DataShape baseDataShape="" description="" documentationContent="" homeMashup="" lastModifiedDate="2018-03-20T14:54:13.211+02:00" name="GanttChartData" projectName="" tags="Applications:GanttChart;Applications:Testing"> <avatar></avatar> <DesignTimePermissions> <Create></Create> <Read></Read> <Update></Update> <Delete></Delete> <Metadata></Metadata> </DesignTimePermissions> <RunTimePermissions></RunTimePermissions> <VisibilityPermissions> <Visibility></Visibility> </VisibilityPermissions> <ConfigurationTables></ConfigurationTables> <FieldDefinitions> <FieldDefinition baseType="NUMBER" description="" name="duration" ordinal="8"></FieldDefinition> <FieldDefinition baseType="DATETIME" description="" name="end" ordinal="4"></FieldDefinition> <FieldDefinition baseType="STRING" description="" name="id" ordinal="1"></FieldDefinition> <FieldDefinition baseType="STRING" description="" name="name" ordinal="2"></FieldDefinition> <FieldDefinition baseType="NUMBER" description="" name="percentage" ordinal="5"></FieldDefinition> <FieldDefinition baseType="STRING" description="" name="relationships" ordinal="7"></FieldDefinition> <FieldDefinition baseType="STRING" description="" name="resource" ordinal="6"></FieldDefinition> <FieldDefinition baseType="DATETIME" description="" name="start" ordinal="3"></FieldDefinition> </FieldDefinitions> </DataShape> </DataShapes> </Entities>
Hope it works and help.
Hi @Sathishkumar_C not sure if you have already tried, is this not working when you create Configuration Table? This creates the datashape fields
Hi @Sathishkumar_C configuration table option which i mentioned would be if you have like a configuration section in your entity.
If you are just looking to create a data shape you can invoke the EntityServices function CreateDataShape()
InfoTable myIF = new InfoTable(); FieldDefinition Field1 = new FieldDefinition("Field1", BaseTypes.INTEGER); EntityServices es = new EntityServices(); String name = "CustomDataShape"; String description = "Created from Extension"; TagCollection myTag = null; myIF.addField(Field1); try { es.CreateDataShape(name, description, myTag, myIF); _logger.info("Successfully created datashape" + es.getName()); } catch (Exception e) { // TODO Auto-generated catch block e.printStackTrace(); _logger.error("Failed to create DS"); }
I don't know if this will help, how can I create a thing that is a data shape on eclipse?
@vxavier may be put it as part of a service in extension and then you can invoke this service on the platform to automatically create that DS entity
- MyExtension.zip
