Create disabled users?
benr
1-Newbie
I'm trying to programmatically create a few dummy users in Thingworx for a demo. I'm able to easily create them using EntityServices.CreateUser, but there doesn't seem to be a service to disable the created user either on EntityServices or on the User object itself. How can I accomplish that on release 5.4?
1 ACCEPTED SOLUTION
paic
1-Newbie
(To:benr)
This will be available in the next release I believe.
7 REPLIES 7
paic
1-Newbie
(To:benr)
stanislav
6-Contributor
(To:paic)
@Pai, do you have are release date for this feature? I am also interested in this feature.
PaiChung
22-Sapphire I
(To:stanislav)
This is in the latest 7.x release part of the user Object. EnableUser and DisableUser
@Pai
I do not have older versions of TWX, but am able to create, disable and enable users using following snippets in Thingworx 7.1
// To create an user
var params = {
    password: <password> /* STRING */,
    name: <name> /* STRING */,
    description: <description> /* STRING */,
    tags: undefined /* TAGS */
Resources["EntityServices"].CreateUser(params);
// To disable an enabled user
Users[<username>].DisableUser();
// To enable a disabled user
Users[<username>].EnableUser();
stanislav
6-Contributor
(To:SajidPatel)
True but it does not create the user as disabled. The user is created as "enabled" than you disable it.
By the way, how can I know if a user is disabled or enabled from within a service.  Is there a property I can check or a service like the one "IsEnabled" available for Things?
In Release 7.1, I see that it is possible to check as follows:
var enabled = Users[<username>].IsEnabled();
stanislav
6-Contributor
(To:SajidPatel)
True, I see it now in 7.1
Thanks Sajid
