I am trying to create integrity item using Integrity lifecycle manager extension in ThingWorx. But I am getting the below error:
Unable to Invoke Service CreateItem on IntegrityConnectorThing : Could not save item: MKS147911: The following fields which are mandatory have not been filled in: Project, Summary, Sprint Start Date, Sprint End Date
I have already created resource provide with type as Sprint.
When I try to add field values in service input it gives error: Must have a datashape to add rows
I need a sample how to use this service and add the required fields with datashape.
Hello priyag3,
Looks like this issue is now being investigated under case C14848775. Please work with the Technical Support Engineer assigned to this case for resolution of this topic.
Tyler Misner
ThingWorx Technical Support Engineer
