Is there a possibility to create a stream programmatically?
According to this thread, I can duplicate a 'prototype' stream, but I have another requirement. I need to create a new stream an I need to choose the data shape of the stream while creating the stream.
Is this possible?
Hi @skef,
It's surely available:
var name = "YourStreamName";
Resources["EntityServices"].CreateThing({
description: undefined,
thingTemplateName: "Stream", // this makes a Thing -> Stream
tags: undefined
// unfortunately, when doing this, we ends up with a new entity with no DataShape and PersistenceProvider
// so we need to set them manually
Things[name].EnableThing();
Things[name].RestartThing();
Things[name].SetDataShape({
// necessary to enable again
// setting a default one
Things[name].SetPersistenceProvider({
For me, working on ThingWorx 8.3 - it's working fine, I can add records later.
Hope it helps.
BR,
JK.
Hi @skef,
tags: undefined
Hope it helps.
BR,
JK.
