Hi all
I have imported the CreatePDF widget from the markeptplace. And under services it has a service "CreatePDF" wherein we have to input the mashup server address etc in order to generate the PDF. It also has an input field for appKey, just wanted to know is it necessary to input the appKey if yes where can I procure one from?
-Ketan
Hi @ketanaga.
The PDF extension that was previously available on the Marketplace has been removed and is not supported by PTC. Perhaps someone else in the community can answer your questions regarding its use.
In regard to generating an appKey, please refer to this page of the ThingWorx Help Center.
Regards.
--Sharon
Hi @ketanaga.
Regards.
--Sharon
Hi @ketanaga.
If my previous response to your post answered your question, please mark it as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
