Hello world,
We are trying to create a service writing the java script code.
But we keep getting the same error message when we test the service (hitting the test button).
We even tried a code copied from another service (which works fine).
The error is: "Invalid Service Name"
Thanks in advance,
bye bye World.
Gustavo, once you created that service, did you save the Thing? Usually, this error occurs if you create a service and don't save the Thing (since it doesn't know a service exists yet).
Thank you Aanjan, that was it!
