I use the "custom chart widget" extension from the marketplace in order to build my charts.
But when I want to load a lot of datas (about 2000) the chart takes between 8 and 12 seconds to build but the sevice which populate the chart runs instantly.
So it is a chart problem, I tried to use the vanilla chart but it only load 2 seconds faster.
Do you know a better plugin or something else ?
Hi Jean-Noel DURAND,
This is a common problem for a bigger set of data and depends not only on the widget itself, but also client's system / browser resources, because rendering requires a lot of resources. One possibility is to create your own widget (e.g. using D3.js library) and optimize the process.
J.
