Hi, I just downloaded the custom chart widget from Marketplace, and I wanted to "try it", so I put it on a mashup together with a 'old' time chart widget.
The result is that, as you may see in the attached image, I can't see at all the new time chart widget in my mashup.
They are binded to the same data.
I saw with Firebug I got this error
11:31:57 ERROR - Runtime exception handling data update for binding
"Id":"087e8764-eda6-494e-95ef-000b13c06836",
"SourceArea":"Data",
"SourceSection":"Things_AggiornaTemperature",
"SourceId":"GetAsyncStream",
"SourceDetails":"AllData",
"TargetArea":"UI",
"TargetSection":"",
"TargetId":"timeserieschart-14",
"PropertyMaps":[{
"SourceProperty":"",
"SourcePropertyType":"InfoTable",
"SourcePropertyBaseType":"INFOTABLE",
"TargetProperty":"Data",
"TargetPropertyType":"property",
"TargetPropertyBaseType":"INFOTABLE"
"isBoundToSelectedRows":false
Exception: data is undefined on line number 68209 in file Combined.7.2.5-b56.20161107.044923.00304.js
I don't know if it may help
