Is it possible create custom dashboards for each user that logs into an organization?
Example. Start off with no dashboards and have them click create a dashboard. The only user that would be able to see the newly created dashboard is the one that created it. This allows each user to have their own custom set of dashboards that no one else can modify or adjust.
Paul
Yes it's possible, it's how we had configured it. Despite you can share Dashboard between Organizational Units to have common dashboards.
Just put the Dashboard widget on a Mashup, and set:
Permissions, on Dashboards CollectionPermissions->
Carles.
Hi Paul, this should be possible by configuring the Dashboard visibility please give this documentation a try.
Hope this helps.
Carles.
Carles,
Thanks this helps a lot!
I would like to mark your answer as correct, but I don't see that option right now.
I have exactly the same demand. The dashboard widget seems to be the perfect solution.
But I don't really find real documentation on how to use it.
How the MashupToAdd shall be implemented?
Is exists some examples or juste a default MashupToAdd dashboard?
How can I link data to the user dashboard?
Regards
