Dears,
We are using custom fonts on Mashup, but it takes a long time to display when the fonts are loaded. Please refer to the attached picture for the font loading method. Is the method we used incorrect?
takes 4.42s
CSS
Hello @CZ_9645217 ,
It could be an issue with the ISP. Maybe the font is retrieved from cache. Link here.
There is a good resource on how to preload or prefetch your font. Link here.
You can check one way to improve mashup performance loading. Link here.
Hope it helps,
Hello @CZ_9645217 ,
Hope it helps,
