I am trying to setup a swagger connector using a remote swagger file located on another server. However, after mapping some of the services I am still required to add some custom headers to the request to the remote service. How do you add your own custom headers to the outgoing requests?
Well, I figured out this one on my own.
I added a swagger thing which uses the swagger connector. I then overrided the "GetCustomHeaderParameters" and returned a result similar to this
var result = { dataShape: { fieldDefinitions : {} }, rows: [] };
result.dataShape.fieldDefinitions["header"] = {
baseType: "STRING"
result.rows=[{"authorization":"Bearer randomTokenString"}];
Which is a response just with one row.
Notice that it should be lowercase "authorization". You can add your custom headers aswell to your liking like x-custom-header. This is then used by the underlying httpclient in thingworx integration run time.
Laterz
baseType: "STRING"
Laterz
