hi, i'm practice custom widget
TW.IDE.Widgets.helloWorld = function () {
this.widgetIconUrl = function() {
return "../Common/extensions/HelloWorld_ExtensionPackage/ui/helloWorld/helloWorld.ide.png";
this.widgetProperties = function () {
return {
"name": "Hello, World!",
"description": "An example widget.",
"category": ['Common'],
"properties": {
"Salutation": {
"baseType": "STRING",
"defaultValue": "Hello, World!",
"isBindingTarget": true
"TextSize":{
"baseType":"NUMBER",
"defaultValue":22,
"isBindingTarget":true
this.renderHtml = function () {
return "<div class=\"widget-content widget-helloWorld\">" +
"<span style=font-size: "+ this.getProperty("TextSize") +"px;>" + this.getProperty("Salutation") + "</span>" +
"</div>";
this.afterSetProperty = function (name, value) {
return true;
this.widgetEvents = function () {
return {
'Updated': {}
Hello, World We tried to construct a user widget that adjusts the font size by moving the slider using the example.(29 line)
However, the font size does not change.
The content inside is also unchanged.
How do I show the values that are bound in the widget?
seonho Cha: Please confirm if this issue is still open and need suggestions.
-Durgesh
Hi, Durgesh Patel
I am trying to create reactive text.
We're still trying it now.
thank
Hello, could you make it works in IDE (Composer) ?
origin hello word extension working
modified hello word extension working but, text size can't change
.salutation {
font-family: Impact, monospace;
font-size: text-size // <- it defined properties in ide.js
text-transform: uppercase;
I am weak in both span, style, and css.
After creating the responsive text, I want to create a thermometer widget.
I have a thermometer picture in the background and I plan to make it by adding Thingworx's vertical slider, but it's not possible at this time (because I do not know everything about span, style, css, value binding,
Is there any material that will help us to get direction in this situation?
thank
You can try with pure html to be sure that the css works.
Then in ThingWorx, on run time, can you see the css set in source code ?
ide and rue time have the same css.
- .salutation {
- font-family: Impact, monospace;
- font-size: text-size // <- it defined properties in ide.js
- text-transform: uppercase;
