Hello everyone,
I have a question about the customer login.
How can customer first access the server without login page?
I mean that customer can see the mashup which i create for main page without login.
Like this page,without login.
Many thanks,
Allen
To do this, you will need to create an "Application Key" for Public Mashups, with a user that only has access to this mashup., then load the corresponding mashup with the "Application Key" embedded on the URL.
Hi Allen,
On this support document you have the correct parameters: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS192696
I tried now and it works, my example:
Hi Carles Coll,
It works!
Thank for your help.
Many thanks,
Allen
