D3 Pie chart with half circle
PM_9712905
Is there a way to make d3 pie chart( donut chart) to show only half circle part?
The reference image is given.
yhan
(To:PM_9712905)
Hi @PM_9712905
The D3 pie chart is not available OOTB. I did some searching and find "Pie Chart to Donut Chart and add boundary to the bar chart" may meet your needs.
You can also refer ThingWorx Extension Development Guide chapter 8 for customized widget implementation.
/Yoyo
4 REPLIES 4
yhan
(To:PM_9712905)
Hi @PM_9712905,
Currently, there is no D3 Pie Chart Widget in ThingWorx OOTB that can load a half-ring Chart.  You need to customize D3 Pie Chart that has a half-ring feature via js as a ThingWorx extension, then import the extension to TWX.
/Yoyo
PM_9712905
(To:yhan)
@yhan Thanks for the quick reply. Can u pls provide link for the d3 chart and also guide for creating extension?
yhan
(To:PM_9712905)
Hi @PM_9712905
/Yoyo
slangley
23-Emerald II
(To:PM_9712905)
Hi @PM_9712905.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
