DATETIME - only show time
SOLVED
Granite
If I have an infotable where one field is a DATETIME, is it possible, when binded to a grid, only show time without date?
Tags (1)
Re: DATETIME - only show time
When you bind your data to Grid, then go to Configure Widget (on the grid), select your date column, then turn on the localization toggle right here:
Then you may go to localization tables and add a new value for date time. You may replace the dateTimeFormat_Default in your Grid widget configuration with that localized value.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
