DPM Production Dashboard
Pratik_Aswale
In DPM production Dashboard, we have a production accounting section inside that it is showing a delay of around 2 hours is it normal?
Please check system time and production accounting time
This is time-zone related. The AC-Cellassembly is probably located in Germany, The "Date and Time" you see is the machine time, so everyone sees the same screen independent from where you consume the mashup.
Pratik_Aswale
(To:Rocko)
Hello Rocko,
Thanks for the response could you please share how to change workunit timezone.
Atharva
I guess you can't, the timezone is defined on site level and can't be updated. Create a new site with the proper timezone and equipment associated to that site.
https://support.ptc.com/help/digital_performance_management/r9.5/en/#page/dpm/digital_performance_management/equipment_list_administration/site_configuration_tab.html
Hello @Pratik_Aswale
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution. Or if you found a solution on your own, please document it in your topic and mark it as accepted solution. This will surely help other users who have similar questions.
Community Moderation Team.
