We have created a gadgets and we are using it in the dashboard.
Sometimes we have to dynamically hide or remove the gadgets from the dashboard.
Due to this there is a lot of blank spaces inside the dashboard.
The empty spaces between the gadgets inside the dashboard is also there incase we are not hiding the gadgets in the dashboard.
Is there a way in thingworx to hide the spaces between the dashboard gadgets in runtime or in a normal way.
Is there also a way in the dashboard to add the gadgets in the right side of the dashboard, not in the horizontal row like it does in the normal way.
Aditya
Aditya, do you get blank spaces between gadgets too? Can you post a screenshot?
