Data Export Extension not importing, won't validate!
aseaton
7-Bedrock
This extension won't validate, help please...
I have followed the guide and no success, could there be an issue with the extension itself?
Andy
1 ACCEPTED SOLUTION
jamesm1
(To:aseaton)
Hey Andy,
It appears this is due to a .jar conflict (specifically bcprov-jdk14-1.38.jar) with Thingworx 7.4+ (well, I am testing on 8.0, so I am making an assumption here). I can remove this jar and successfully get the package to import -- you can try the copy I have here: Dropbox - DataExporterExtension_v1.0.zip -- but I can't guarantee the extension will still work as intended (a different version of that library appears to come with the TWX platform).
As this is a Thingworx Labs extension, it is tested but not officially supported; see the marketplace posting:
Support
This item has been tested and certified by ThingWorx to successfully work with the ThingWorx platform, however this item is not currently supported by ThingWorx. By utilizing this item you acknowledge that the content is provided in ‘as-is’ condition and support will not be provided.
Beyond this, if you are still having issues, we may need to track down the developer and see if they are willing to share their project code and/or provide an update to support more recent versions of TWX.
6 REPLIES 6
jamesm1
(To:aseaton)
Hey Andy,
Are there any more details in the Thingworx Application logs? It may be that it is incompatible with your version of Thingworx?
Thanks!
aseaton
7-Bedrock
(To:jamesm1)
Hi James,
There are no details in the logs. I am using version 7.4.0-b159.
Andy
jamesm1
(To:aseaton)
Hey Andy,
It looks like you might be trying to import the TW_Download_Data Export Extension.zip directly; but after looking at this download on the marketplace it appears the extension is actually zipped in a subfolder of that archive, Data Exporter Extension Package, as DataExporterExtension_v1.0.zip
Can you try unzipping DataExporterExtension_v1.0.zip and importing that as the extension, instead of the wrapper archive?
aseaton
7-Bedrock
(To:jamesm1)
I get the following error message after your suggestion:
different from before in that there is no message. Difficult to see where to go from here, also nothing in the logs.
Appreciate your response.
Andy
jamesm1
(To:aseaton)
Hey Andy,
Support
aseaton
7-Bedrock
(To:jamesm1)
Thanks for the fantastic support James - i shall try to use your copy and hopefully my requirements can be met.
Andy
