Hi ,
I have DataTable with some records , i want to use Data filter widget .but when i binds filter widget to "All Data" in Datatable Service . its showing field names in filter widget but unable to filter data. i need proper reference on it. which service needs to bind and which needs to create new one. i have attached screenshots plz see this and give some steps how we can get it.
I recommend to use QueryDataTableEntries and create bindings in the following order:
- bind the Query from Data Filter to Query from Parameters of service QueryDataTableEntries
- Change event of filter bind it with QueryDataTableEntries service
See below:
Hope it helps,
Raluca Edu
See below:
Hope it helps,
Raluca Edu
Thank you very much . perfect !!
Bindings remain the same, the only thing is that you need to create a service that is getting all rows of an infotable and one service that is doing query in infotable. I do not have a code example for this, but for querying infotable you can use:
var query = {
sorts:[{
fieldName: "name_of_field",
isAscending: false
filters: {
type: "AND",
filters:
type: "LT",
value: 20 // this is selecting field values less than 20
var result = Resources['InfoTableFunctions'].Query(
{query : query,
t : myinfotable
But you need to figure it out how to create a dynamic query for infotable that is selected by user and then to pass it to your service.
Hope it helps,
Raluca Edu
