I have a requirement of displaying data points on top of each bar in the chart. I tried available custom widgets, not worked for me.
Please find the below image for your reference.
Janakiraman P
Hi @Janakiraman.
The value should be displaying when you hover, but if you wish for it to be visible above all bars, it appears that you will need to create your own widget to do this. You could start with one we provide. The documentation to do so is available here.
If you still have questions after reviewing the guide, please let us know.
Regards.
--Sharon
I think that marketplace Custom Chart Widgets can do it: https://marketplace.ptc.com/apps/216584/custom-chart-widgets-v302#!overview
Hi Carles,
We have tried it already, not working for the above requirement.
Janakiraman P
Hi @Janakiraman.
Regards.
--Sharon
Hi @Janakiraman.
If the previous response allowed you to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
