Data table creation through service scripting
muzzammil
How can i create data table(s) with its data shape through service scripting?
mnarang
(To:muzzammil)
The DataShape which you are passing in the above shared code can also be created through script having primary key
var result1 = { dataShape: { fieldDefinitions : {abc: {name: "abc", aspects: {isPrimaryKey: true}, description: "", baseType: "STRING", ordinal: 1}} }, rows: [] };
var params = {
name: "DSwithPK" /* STRING */,
description: undefined /* STRING */,
fields: result1 /* INFOTABLE */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateDataShape(params);
Hope it helps
Thanks ,
Mukul Narang
mnarang
(To:muzzammil)
I have done in this way :
var params = {
name: "MyTestTable1" /* STRING */,
thingTemplateName: "DataTable" /* THINGTEMPLATENAME */,
// no return
Resources["EntityServices"].CreateThing(params);
Things["MyTestTable1"].SetDataShape({
name: "DataShapeWithBoolean" /* DATASHAPENAME */
Things["MyTestTable1"].EnableThing();
Things["MyTestTable1"].RestartThing();
Hope it helps .
Thanks ,
Mukul Narang
muzzammil
(To:mnarang)
how to set the data shape field as the primary key through scripting?
mnarang
(To:muzzammil)
var params = {
// no return
Hope it helps
Thanks ,
Mukul Narang
muzzammil
(To:mnarang)
@mnarang Thank you...it was helpful
mnarang
(To:muzzammil)
Can you please mark it as accepted solution so that it can help other people as well !!
Thanks ,
Mukul Narang
