Decrypting Property Value
ShirishMorkhade
Hi ThingWorx Enthusiast,
Which service, resource to use to decrypt the property value which is encrypted using below snippet?
var params = {
data: "<Some_Value>" /* STRING */
// result: STRING
var result = Resources["EncryptionServices"].EncryptPropertyValue(params);
I didn't find relevant decrypt service under EncryptionServices resource and wonder how to get back the original value.
Shirish
4 REPLIES 4
Hello @ShirishMorkhade ,
Have you tried the following approach:
var property= me.Prop;
var params1 = {
data: property /* STRING */,
key: "FEDCBA98765432100123456789ABCDEF" /* STRING */
// result: STRING
var result1 = Resources["EncryptionServices"].EncryptWithCustomKey(params1);
var params2 = {
encryptedData: result1 /* STRING */,
// result: STRING
var result = Resources["EncryptionServices"].DecryptWithCustomKey(params2);
Hope it helps,
Hi @ShirishMorkhade , Please mark the solution as accepted if it worked for your query.
Regards
Ankur
@Ciprian-Traian @anarwal
Yes we already tried this approach but use case don't allow us to rely on any key due to security measures.
Hence I was very specifically in the question about EncryptPropertyValue
Shirish
It seems there isn't a direct way to decrypt, however, you can use the following from the Extension SDK: BaseTypes.ConvertToPrimitive, PasswordPrimitive.convertFromObject, PasswordPrimitive.getDecryptedValue
More information can be found on the ThingWorx Help Center Encryption
.Hope it helps,
