any idea where to find the default tooltip localization tokens (ex. ScheduleChartDefaultTooltip ) for the charts (see link)? I haven't find them on the loctokens.
Hi @bot1q,
If you haven't found them probably because your ThingWorx version is not above 9.2
As mentioned in Help Center: The following charts include support for custom tooltips in ThingWorx 9.2 and later:
In ThingWorx version 9.2 or later you should see in the localization table as below
Hi @bot1q,
