var size = me.Intruders.getRowCount();
var i=0;
for (i=0;i<size;i++)
if (me.Intruders.rows.Age == Intruders.Age){
DeleteItem(i);
break;
function DeleteItem(i)
{ if(i!=0){
me.Intruders.RemoveRow(i);
This is not working , can someone help?
Intruders.Age is a selected row infotable (input parameter) and I am looking to delete a row from Intruders infotable with the Age from selected row.
var i;
if (me.Intruders.rows[i].Age == Intruders.Age){
result = "nice";
var myTempTable = me.Intruders;
myTempTable.RemoveRow(i);
me.Intruders = myTempTable;
break;
Thank you for the help, here is the working code if someone needs it.
It deletes the date based on row parameter.
When you say this is not working, are you getting errors?
Is the infotable persisted or not?
you are doing a direct in memory operation which would mean that is the infotable is persisted, it will retain the original content after a thing restart or system restart.
There are no errors, Yes the infotable is presisted.
The Service does not delete a row because the infotable is persisted ?
After the executions, the specific row is still there. It doesn't delete it.
To make a persistent delete in an InfoTable property you have to completely re-write the property
so
Try accessing the value of the property directly. Use +me.Intruders.rows.Age in your if condition statement.
Like : if (+me.Intruders.rows.Age == Intruders.Age).
var i;
result = "nice";
break;
