I would like to know how to use DeleteStreamEntry service in a stream. It seems to not work at all.
Thanks in advance,
Sujith
Thanks for reaching out to us. Can you check below thread if helps or not.
https://community.ptc.com/t5/ThingWorx-Developers/delete-values-from-stream/m-p/505719
Let me in case of any question.
Mohit
Mohit
Hi @SB_9732186
Did you get a chance to my previous response. If you feel that was the answer of your query please mark it accept as solution for benefit of other community users. Or let us know in case you are still having this issue.
Mohit
