Delete all records of single column of data table.
magrawal
2-Explorer
Hi All,
As title stated, Is there a way to delete entries of individual columns in data table.
Meenakshi
ttielebein
(To:magrawal)
You'd have to write a script that locates the row you want to modify and then set the field you want to delete to some null value. You can't delete an individual column from an individual row without deleting that same column for the whole table. Hope this helps!
Thanks Tori Tielebein
You can't delete an individual column from an individual row without deleting that same column for the whole table ->> This is the only way I found to delete all data for a particular column.
Meenakshi
